Desmond Caldwell Can't add backup system in oVirt, help! Error log: #201 Curl Error: unable to connect
Sylas Beaumont Check if the IP address used when adding oVirt is the node's IP address. If so, it needs to be changed to the engine's IP address.
Desmond Caldwell I'm so sorry it took me so long to reply. The problem has been solved. Thank you so much!
