Hi — after the retention policy runs a backup job won’t merge (Apteka-April 8.0.0.45129). Error:
Failed to complete retention policy check for VM 'Test',[#54] Restore point is in use, please stop corresponding job then try again.
The job is stuck and won’t commit/remove points. Any idea what “restore point is in use” means and how to force/clear the merge? I can paste job logs or active job list if that helps.
