Tobias Whitmore Hi Tobias,
I wanted to share the issue we encountered when booting the VM:
Issue:
The VM fails to boot because the CPU type needs to be adjusted.
Error log:
end Kernel panic - not syncing: Attempted to kill init! Exit code=0x00007f00
Solution:
Depending on the virtualization platform, adjust the CPU mode or boot method as follows:
ZStack: Set to host-model
H3C: Set to host passthrough
Sangfor HCI: Enable host CPU
SCP: Change vCPU type to Haswell-noTSX
Inspur iCS Vvdk: Set to SANDBRIDGE
Proxmox: Choose host or Haswell-noTSX
Huawei KVM: Use UEFI boot; BIOS will fail
OpenStack: ISO cannot be used directly; a bootable disk must be created first
Hope this can help you!
