Vinchin supports agentless backup for Hyper-V VM, you can use the backup to restore Hyper-V VM or perform V2V migration.
Before adding the host, you need to install a plugin on the Hyper-V host.
Then you can add the Hyper-V host with its credentials.
Backup Hyper-V VM:
After adding the Hyper-V host, you can create a backup task in 4 steps.
- Select the Hyper-V VMs you want to backup.
Restore Hyper-V VM:
When you need to restore a Hyper-V VM, just select the restore point in the system and create a restore job in 4 steps.
- Select the restore point from Hyper-V backup data
Except for full VM restore, you can also use it to perform granular restore to quickly extract file from it.
