Hi, you can try the following steps to resolve this issue:
Root Cause:
The wrong virtual platform type was selected when adding the platform.
The username or password entered for the platform is incorrect.
Resolution:
Please go to Resources > Infrastructure > Virtual Platform > Add, and ensure you select the correct platform type (e.g., Hyper-V).
Verify that the username and password used to connect to the virtual platform are accurate and have the necessary permissions.
Let me know if it works or if you need further assistance. 😊
